[GRASS-dev] Re: [GRASS GIS] #1131: Global LFS for wingrass
trac at osgeo.org
Sat Aug 14 14:36:26 EDT 2010
Reporter: mmetz | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: libgis | Version: svn-trunk
Keywords: LFS,wingrass | Platform: MSWindows 7
Cpu: All |
Comment(by mmetz):
Replying to [comment:2 glynn]:
> Replying to [comment:1 mmetz]:
> > Following up previous discussions, I have removed struct stat where
possible. The changes needed for LFS with wingrass are in config.h.in but
still inactive.
> > Glynn, could you please check if I messed up something somewhere (all
the struct stat related changes and config.h.in)?
> The config.h.in changes seem okay.
They were not. STRUCT_STAT needs the be always defined, fixed.
> Although, I would omit the aliases for seek() and tell()
Done.
> I don't see any "struct stat" changes. Currently, 7.0 has references to
"struct stat" in:
> display/d.font/main.c
> general/g.access/get_perms.c
> general/g.mkfontcap/freetype_fonts.c
> include/gisdefs.h
> include/iostream/ami_stream.h
> lib/db/dbmi_base/isdir.c
> lib/gis/copy_dir.c
> lib/gis/mapset_msc.c
> lib/gis/mapset_nme.c
> lib/gis/paths.c
> lib/gis/remove.c
> lib/gis/user_config.c
> lib/init/clean_temp.c
> lib/vector/Vlib/open.c
> lib/vector/dglib/examples/parse.c
> lib/vector/diglib/file.c
> raster/r.li/r.li.daemon/daemon.c
> vector/v.mapcalc/map.c
That was the first step, to get some feedback without actually changing
anything. In theory, LFS for wingrass is now working as of r43115 in
trunk. In practice, global LFS in trunk is working as before on Linux.
Some remarks:
Everything related to fonts: the stat'ed file might be opened by another
program?
Shouldn't the check here also check if path is a dir?
Needs some cleaning up, unused functions (coor file is never loaded to
memory).
There is a temporary check for LFS hidden in v.info, visible with DEBUG=1.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1131#comment:3>
