[GRASS-dev] Nightly WinGrass-builds (65,70) broken
Markus Metz
markus.metz.giswork at googlemail.com
Sat Aug 14 11:19:24 EDT 2010
Helmut Kudrnovsky wrote:
> Hi Martin,
> -----Ursprüngliche Nachricht-----
> Von: Martin Landa Gesendet:
> 14.08.2010 13:27:17
> An: Helmut Kudrnovsky
> Betreff: Re: [GRASS-dev] Nightly WinGrass-builds (65,70) broken
>>2010/8/14 Helmut Kudrnovsky
>> the nightly Wingrass65- and WinGrass70-builds seems to be broken:
>>> [http://josef.fsv.cvut.cz/wingrass/grass65/] => no files
>>> [http://josef.fsv.cvut.cz/wingrass/grass70/] => last build from 10-Aug-2010 16:01
>>yes, the problem are ctypes. Probably it would be better to disable it
>>on Windows.
> as you can see in my other mail about WinGrass70 compiling error
> ([http://lists.osgeo.org/pipermail/grass-dev/2010-August/051577.html]),
> there seems to be an additional cause for failing wingrass7.
> I've tried compiling wingrass65, there is only the ctypes problem.
> I've tried to start wingrass out of C:\OSGeo4W\usr\src\grass6_devel\bin.i686-pc-mingw32,
> there is following error:
> GRASS 6.5> Traceback (most recent call last):File "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/wxgui.py", line 65, in import gui_modules.layertree as layertreeFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/layertree.py", line 40, in import toolbarsFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/toolbars.py", line 42, in from nviz import haveNvizFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/nviz.py", line 29, in import nviz_mapdispFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/nviz_mapdisp.py", line 39, in from workspace import Nviz as NvizDefaultFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/workspace.py", line 40, in import wxnvizFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/wxnviz.py", line 59, in errtype = CFUNCTYPE(UNCHECKED(c_int), String, c_int)NameError: name 'UNCHECKED' is not defined
same on linux
why is wxnviz loaded on startup?
Markus M
