[GRASS-dev] Nightly WinGrass-builds (65,70) broken
Helmut Kudrnovsky hellik at web.de
Sat Aug 14 17:06:10 EDT 2010
>-----Ursprüngliche Nachricht-----
>Von: Markus Metz
>Gesendet: 14.08.2010 17:19:24
>An: Helmut Kudrnovsky hellik at web.de>
>Betreff: Re: [GRASS-dev] Nightly WinGrass-builds (65,70) broken
>Helmut Kudrnovsky wrote:
> Hi Martin,
>> Von: Martin Landa Gesendet:
>> 14.08.2010 13:27:17
>>>2010/8/14 Helmut Kudrnovsky
>>> the nightly Wingrass65- and WinGrass70-builds seems to be broken:
>>>> [http://josef.fsv.cvut.cz/wingrass/grass65/] => no files
>>>> [http://josef.fsv.cvut.cz/wingrass/grass70/] => last build from 10-Aug-2010 16:01
>>>yes, the problem are ctypes. Probably it would be better to disable it
>>>on Windows.
> >as you can see in my other mail about WinGrass70 compiling error
> >([http://lists.osgeo.org/pipermail/grass-dev/2010-August/051577.html]),
> >there seems to be an additional cause for failing wingrass7.
> >I've tried compiling wingrass65, there is only the ctypes problem.
> >I've tried to start wingrass out of C:\OSGeo4W\usr\src\grass6_devel\bin.i686-pc-mingw32,
> >there is following error:
> >GRASS 6.5> Traceback (most recent call last):File "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/wxgui.py", line 65, in  import >gui_modules.layertree as layertreeFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/layertree.py", line 40, in  import >toolbarsFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/toolbars.py", line 42, in  from nviz import >haveNvizFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/nviz.py", line 29, in  import >nviz_mapdispFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/nviz_mapdisp.py", line 39, in  from workspace import Nviz >as NvizDefaultFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/workspace.py", line 40, in  import >wxnvizFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/wxnviz.py", line 59, in  errtype = CFUNCTYPE(UNCHECKED(c_int), >String, c_int)NameError: name 'UNCHECKED' is not defined
>same on linux
>why is wxnviz loaded on startup?
>Markus M
and after solving compiling wingrass7, it's the same here, when I want to start the wxgui:
GRASS 7.0.svn> Traceback (most recent call last): File "C:\Program Files\GRASS-70-SVN\etc\gui\wxpython\wxgui.py", line 65, in  import gui_modules.layertree as layertreeFile "c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/gui/wxpython/gui_modules/layertree.py", line 40, in  File "c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/gui/wxpython/gui_modules/toolbars.py", line 42, in  File "C:\Program Files\GRASS-70-SVN\etc\gui\wxpython\gui_modules\nviz.py", line 29, in  import nviz_mapdispFile "C:\Program Files\GRASS-70-SVN\etc\gui\wxpython\gui_modules\nviz_mapdisp.py", line 40, in  from workspace import Nviz as NvizDefaultFile "C:\Program Files\GRASS-70-SVN\etc\gui\wxpython\gui_modules\workspace.py", line 40, in  import wxnvizFile "C:\Program Files\GRASS-70-SVN\etc\gui\wxpython\gui_modules\wxnviz.py", line 59, in  errtype = CFUNCTYPE(UNCHECKED(c_int), String, c_int)NameError: name 'UNCHECKED' is not defined
best regards
Helmut
___________________________________________________________
WEB.DE DSL SOMMER-SPECIAL: Surf & Phone Flat 16.000 für
nur 19,99 ¿/mtl.!* http://web.de/DSL-Doppel-Flatrate/
