[GRASS-dev] Nightly WinGrass-builds (65,70) broken
Martin Landa landa.martin at gmail.com
Mon Aug 16 14:51:04 EDT 2010
2010/8/14 Markus Metz <markus.metz.giswork at googlemail.com>:
>> I've tried compiling wingrass65, there is only the ctypes problem.
>> I've tried to start wingrass out of C:\OSGeo4W\usr\src\grass6_devel\bin.i686-pc-mingw32,
>> there is following error:
>> GRASS 6.5> Traceback (most recent call last):File "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/wxgui.py", line 65, in  import gui_modules.layertree as layertreeFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/layertree.py", line 40, in  import toolbarsFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/toolbars.py", line 42, in  from nviz import haveNvizFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/nviz.py", line 29, in  import nviz_mapdispFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/nviz_mapdisp.py", line 39, in  from workspace import Nviz as NvizDefaultFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/workspace.py", line 40, in  import wxnvizFile "c:/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/gui_modules/wxnviz.py", line 59, in  errtype = CFUNCTYPE(UNCHECKED(c_int), String, c_int)NameError: name 'UNCHECKED' is not defined
> same on linux
> why is wxnviz loaded on startup?
yes, wxnviz is loaded on the startup because of a little bit
complicated modules dependency. It could be possible to avoid loading
wxnviz on startup. Or to keep the current behaviour and catch up
errors caused by wxnviz more precisely. Now should be fixed in trunk
and devbr6. The next winGRASS should be built correctly.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
