[GRASS-dev] Re: [GRASS GIS] #1131: Global LFS for wingrass
GRASS GIS trac at osgeo.org
Sat Aug 14 16:15:50 EDT 2010
 Reporter:  mmetz         |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  critical      |   Milestone:  7.0.0
Component:  libgis        |     Version:  svn-trunk
 Keywords:  LFS,wingrass  |    Platform:  MSWindows 7
      Cpu:  All           |
Comment(by glynn):
 Replying to [comment:3 mmetz]:
 > Some remarks:
 > Everything related to fonts: the stat'ed file might be opened by another
 program?
 general/g.mkfontcap/freetype_fonts.c
 display/d.font/main.c
 This only tests for existence and type. Ideally, we should have e.g.
 G_file_exists(), G_file_is_file() and G_file_is_directory() and use those
 (the last two need a flag to indicate whether to use stat() or lstat()).
 That would probably eliminate many of the stat() calls. Also,
 G_file_size(). It's better to keep as much of this in the library as
 possible.
 > Shouldn't the check here also check if path is a dir?
 lib/gis/mapset_nme.c
 It should check that WIND is a file, rather than checking that it isn't a
 directory.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1131#comment:6>
