[GRASS-dev] Re: [GRASS GIS] #1131: Global LFS for wingrass
GRASS GIS trac at osgeo.org
Sat Aug 14 16:18:36 EDT 2010
 Reporter:  mmetz         |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  critical      |   Milestone:  7.0.0
Component:  libgis        |     Version:  svn-trunk
 Keywords:  LFS,wingrass  |    Platform:  MSWindows 7
      Cpu:  All           |
Comment(by hellik):
 Replying to [comment:5 mmetz]:
 > Please test!
 > Markus M
 a quick compiling test with r43116
 checking for special C compiler options needed for large files... no
 checking for _FILE_OFFSET_BITS value needed for large files... no
 checking for _LARGE_FILES value needed for large files... no
 checking for _LARGEFILE_SOURCE value needed for large files... no
 checking for fseeko... no
 checking if system supports Large Files at all... yes
 GRASS is now configured for:  i686-pc-mingw32
   Source directory:            /c/osgeo4w/usr/src/grass_trunk
   Build directory:             /c/osgeo4w/usr/src/grass_trunk
   Installation directory:      ${prefix}/grass-7.0.svn
   Startup script in directory: ${exec_prefix}/bin
   C compiler:                  gcc -g -O2
   C++ compiler:                c++ -g -O2
   Building shared libraries:   yes
   64bit support:
   OpenGL platform:             Windows
   MacOSX application:         no
   MacOSX architectures:
   MacOSX SDK:
   NVIZ:                       yes
   BLAS support:               no
   C++ support:                yes
   Cairo support:              no
   DWG support:                no
   FFMPEG support:             no
   FFTW support:               yes
   FreeType support:           yes
   GDAL support:               yes
   GEOS support:               no
   JPEG support:               yes
   LAPACK support:             no
   Large File support (LFS):   yes
   MySQL support:              no
   NLS support:                yes
   ODBC support:               yes
   OGR support:                yes
   OpenGL support:             yes
   PNG support:                yes
   PostgreSQL support:         yes
   Python support:             no
   Readline support:           no
   SQLite support:             yes
   Tcl/Tk support:             yes
   wxWidgets support:          no
   TIFF support:               yes
   X11 support:                no
   Regex support:              yes
   POSIX thread support:       no
 Started compilation: Sat Aug 14 19:14:40 GMT 2010
 Errors in:
 /c/osgeo4w/usr/src/grass_trunk/lib/vector/diglib
 /c/osgeo4w/usr/src/grass_trunk/lib/python/ctypes
 syringia at NADA /c/osgeo4w/usr/src/grass_trunk/lib/vector/diglib
 $ make
 if [ "" != "" -a -f "".html ] ; then make html ; fi
 ==============TEST=============
 make test
 make[1]: Entering directory
 `/c/osgeo4w/usr/src/grass_trunk/lib/vector/diglib'
 diff OBJ.i686-pc-mingw32/test.tmp test64.ok
 Files OBJ.i686-pc-mingw32/test.tmp and test64.ok differ
 make[1]: *** [test] Error 2
 make[1]: Leaving directory
 make: *** [default] Error 2
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1131#comment:7>
