[GRASS-dev] wxnviz on mac osx (grass7.0)
Massimo Di Stefano massimodisasha at gmail.com
Thu Aug 19 10:36:07 EDT 2010
Hi William,
right :-) thanks to point me to tcltk
i'm on a fresh osx installation .. so i'll rebuild tcltk for both 32+64 bit and reconfigure grass.
but this error wil be not related to the wx-nviz crash, is it right ?
i have a wxniz crash on both grass 6.5 and 7.0.
i'll update my tcltk and try again,
thanks!
Massimo.
Il giorno 19/ago/2010, alle ore 16.30, William Kyngesburye ha scritto:
> That's the TclTk NVIZ.
> And it looks like it's configured for the system TclTk (8.5).  I tried that a while back when Snow Leopard came out - updated tcltk, 64bits - but had problems compiling, it might have been the same error.
> You need to install TclTk 8.5 from ActiveState and configure for that.  See the Mac compile readme in the source.
> On Aug 19, 2010, at 6:42 AM, Massimo Di Stefano wrote:
>> Hi,
>> problems to get wx-nviz running on mac osx 10.6.4 building grass7.0
>> this the log :
>> Finished compilation: Gio 19 Ago 2010 13:31:39 CEST
>> make: *** [default] Error 1
>> MacBook-Pro-15-di-sasha:grass_trunk sasha$ cd /Users/sasha/gis/grass_trunk/visualization/nviz
>> MacBook-Pro-15-di-sasha:nviz sasha$ make
>> make -C src
>> gcc  -g -O2    -arch i386 -arch x86_64  -I/Users/sasha/gis/grass_trunk/dist.i386-apple-darwin10.4.0/include -I/Users/sasha/gis/grass_trunk/dist.i386-apple-darwin10.4.0/include  -D_FILE_OFFSET_BITS=64   -I/Users/sasha/gis/grass_trunk/dist.i386-apple-darwin10.4.0/include -I/Users/sasha/gis/grass_trunk/dist.i386-apple-darwin10.4.0/include -I/Library/Frameworks/UnixImageIO.framework/unix/include  -I/Library/Frameworks/GDAL.framework/Versions/1.7/Headers -I/Library/Frameworks/GEOS.framework/Versions/3/unix/include  -DPACKAGE=\""grassmods"\"   -I/Users/sasha/gis/grass_trunk/dist.i386-apple-darwin10.4.0/include -I/Users/sasha/gis/grass_trunk/dist.i386-apple-darwin10.4.0/include -o OBJ.i386-apple-darwin10.4.0/togl.o -c togl.c
>> In file included from togl.c:53:
>> /usr/include/tkMacOSX.h:31: error: expected declaration specifiers or ‘...’ before ‘TkRegion’
>> togl.c:54:54: error: tkMacOSXInt.h: No such file or directory
>> togl.c:265: error: expected specifier-qualifier-list before ‘XVisualInfo’
>> togl.c: In function ‘SetMacBufRect’:
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> [Trillian]  What are you supposed to do WITH a maniacally depressed robot?
> [Marvin]  You think you have problems?  What are you supposed to do if you ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
> - HitchHiker's Guide to the Galaxy
