[GRASS-dev] Re: [GRASS GIS] #1125: wingrass - ctypes - compiling
error
trac at osgeo.org
Wed Aug 25 15:48:35 EDT 2010
#1125: wingrass - ctypes - compiling error
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.5.0
Component: Compiling | Version: svn-trunk
Keywords: wingrass, ctypes | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by martinl):
Replying to [comment:39 glynn]:
> > and all files seems to be build in
> > C:\OSGeo4W\usr\src\grass6_devel\dist.i686-pc-
mingw32\etc\python\grass\lib
> > but during wingrass65-startup I get:
> 3D view mode not available
> Reason: grass_datetime not found.
> Is ctypes being invoked with -lgrass_datetime.7.0.svn or
-lgrass_datetime?
> Check that $GISBASE/etc/python/grass/lib/date.py has:
> _libs["grass_datetime.7.0.svn"] = load_library("grass_datetime.7.0.svn")
> Also, check that you don't have an old version lying around.
Helmut is refering to GRASS 6.5 which uses versioned/unversioned libs. The
solution could be to adopt build system in GRASS 6.5 to use only versioned
libs as in GRASS 7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1125#comment:40>
