[GRASS-dev] Re: [GRASS GIS] #1125: wingrass - ctypes - compiling
error
trac at osgeo.org
Wed Aug 25 15:55:12 EDT 2010
#1125: wingrass - ctypes - compiling error
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.5.0
Component: Compiling | Version: svn-trunk
Keywords: wingrass, ctypes | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:40 martinl]:
> Replying to [comment:39 glynn]:
> > > and all files seems to be build in
> > > C:\OSGeo4W\usr\src\grass6_devel\dist.i686-pc-
mingw32\etc\python\grass\lib
> > > but during wingrass65-startup I get:
> > 3D view mode not available
> > Reason: grass_datetime not found.
> > Is ctypes being invoked with -lgrass_datetime.7.0.svn or
-lgrass_datetime?
> > Check that $GISBASE/etc/python/grass/lib/date.py has:
> > _libs["grass_datetime.7.0.svn"] =
load_library("grass_datetime.7.0.svn")
> > Also, check that you don't have an old version lying around.
> Helmut is refering to GRASS 6.5 which uses versioned/unversioned libs.
The solution could be to adopt build system in GRASS 6.5 to use only
versioned libs as in GRASS 7.
You're right.
wingrass65:
C:\OSGeo4W\apps\grass\grass-6.5.svn\etc\python\grass\lib\date.py
_libs["grass_datetime"] = load_library("grass_datetime")
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1125#comment:41>
