[GRASS-dev] Re: [GRASS GIS] #1125: wingrass - ctypes - compiling error
GRASS GIS trac at osgeo.org
Thu Aug 26 03:44:23 EDT 2010
 Reporter:  hellik            |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  blocker           |   Milestone:  6.5.0
Component:  Compiling         |     Version:  svn-trunk
 Keywords:  wingrass, ctypes  |    Platform:  MSWindows Vista
      Cpu:  x86-32            |
Comment(by glynn):
 Replying to [comment:40 martinl]:
 > Helmut is refering to GRASS 6.5 which uses versioned/unversioned libs.
 Right. So it's linking against the unversioned lib but only installing the
 versioned one?
 > The solution could be to adopt build system in GRASS 6.5 to use only
 versioned libs as in GRASS 7
 Another alternative is to just keep both versions.
 It may be possible to make lib/python/ctypes/Makefile use the versioned
 name, e.g.:
 -       $$(call run_grass,$(CTYPESGEN) $(CTYPESFLAGS) $$($(1)_LIBS)
 $$($(1)_INC) $(EXTRA_LIBS) $$($(1)_DEPS) -o $$@)
 +       $$(call run_grass,$(CTYPESGEN) $(CTYPESFLAGS) $$(patsubst
 -lgrass_%,-lgrass_%.$(GRASS_VERSION_NUMBER),$$($(1)_LIBS)) $$($(1)_INC)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1125#comment:42>
