[GRASS-dev] [GRASS GIS] #1231: v.parallel cycles
trac at osgeo.org
Mon Dec 6 05:33:19 EST 2010
Reporter: akbgf | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.parallel | Platform: Linux
Cpu: x86-32 |
GRASS-7.0 r44543
There are occasions that v.parallel can not create parallel lines to a
line, v.parallel cycles forever.
Attached please find a small raster r35.txt and vector v35.txt which has a
line and a centroid. The following sequence of commands will create an
infinite loop:
r.in.ascii -i --overwrite input=r35.txt output=r35[[BR]]
v.in.ascii --overwrite input=v35.txt output=v35 format=standard
fs='space'[[BR]]
v.parallel -b input=v35 layer=-1 output=v35b distance=10 side=both
--overwrite
Andres Kuusk, Tartu Observatory, Estonia, andres at aai.ee
Ticket URL: <http://trac.osgeo.org/grass/ticket/1231>
