[GRASS-dev] Re: [GRASS GIS] #1231: v.parallel cycles
GRASS GIS trac at osgeo.org
Fri Dec 10 11:35:13 EST 2010
 Reporter:  akbgf              |       Owner:  grass-dev@…
     Type:  defect             |      Status:  new
 Priority:  normal             |   Milestone:  7.0.0
Component:  Vector             |     Version:  svn-trunk
 Keywords:  v.parallel, patch  |    Platform:  Linux
      Cpu:  x86-32             |
Changes (by yawl):
  * keywords:  v.parallel => v.parallel, patch
Comment:
 The function
 void link__set_next(VOID_T * a, VOID_T * b)
 in lib/linkm/next.c corrupted the
 struct Slink
     double x;
     struct Slink *next;
 defined in lib/vector/Vlib/poly.c
 by modifying x instead of *next.
 The patch is attached as grass.diff
Ticket URL: <http://trac.osgeo.org/grass/ticket/1231#comment:1>
