[GRASS-dev] Re: [GRASS GIS] #1230: <suppress_required/> in r.out.gdal
GRASS GIS trac at osgeo.org
Mon Dec 6 17:21:10 EST 2010
  Reporter:  rsbivand     |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  major        |   Milestone:  7.0.0
 Component:  Raster       |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment(by hamish):
 Replying to [comment:2 rsbivand]:
 > I have to work within the XML library linked by the XML R
 > contributed package, so if that barfs, I'm stuck.
 If R's XML package can't deal with <foo />, then we should probably file a
 bug with them. While not in every XML file it's a somewhat common creature
 and I'd be a little surprised if you were the first person to find this
 problem, and you certainly wont be the last.
 Hamish
 ps- is the missing newline after the tag real or just an artifact of the
 trac editor?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1230#comment:4>
