[GRASS-dev] Re: [GRASS GIS] #1230: <suppress_required/> in
r.out.gdal
trac at osgeo.org
Tue Dec 7 00:44:07 EST 2010
#1230: <suppress_required/> in r.out.gdal
Reporter: rsbivand | Owner: grass-dev@…
Type: defect | Status: closed
Priority: major | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Resolution: fixed | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment(by glynn):
Replying to [comment:2 rsbivand]:
> It may be permitted, but is much less obvious than
> <suppress_required>yes</suppress_required>
> <suppress_required>no</suppress_required>
> which is arguably more portable.
XML's support for the abbreviation of empty tags isn't an optional
feature. If a parser doesn't handle it, it isn't an XML parser, it's a
parser for an entirely different language.
> I have to work within the XML library linked by the XML R contributed
package, so if that barfs, I'm stuck. One problem seems to be that
<description> has typically always been the first component, but where
<suppress_required> appears, it is now first.
I note that the --interface-description output doesn't conform to the
stated DTD. But that was true before the suppress_required element was
added (e.g. the DTD doesn't list "guisection" elements as being valid
children for "flag" elements), so I'm guessing that this isn't actually
the problem.
I'm willing to fix both the DTD and the --interface-description output so
that they match, although someone (probably Martin) will need to update
the wx GUI. Based upon existing usage, I think that suppress_required may
be better off as an attribute rather than a child element. OTOH, the split
between which fields are attributes and which are child elements is rather
arbitrary.
> So some modules will optionally get an out-of-order component which,
when present, means yes, and when absent means no? I guess I'm going to
have to add code to loop through each flag entry checking the XML names,
and set yes/no myself.
You should be doing that anyhow. Most of the fields are marked as optional
according to the DTD, so you can't assume that e.g. the first child is a
description element.
You can just ignore the suppress_required element if you aren't checking
requirements. The wx GUI does check requirements, so that element had to
be included in the interface description to prevent it from complaining
(unnecessarily) about missing options.
> Is the logic here that if I say "r.in.gdal -f", and if suppress_required
is not set, one of the parameters may apply its required=YES value to
terminate execution?
Yes. Previously, if a module had a "special case" flag which invoked a
different mode of execution, all of its options had to be listed as
->required=NO. The addition of the suppress_required fields allows
options' ->required fields to be set based upon "normal" usage, rather
than "worst-case" usage.
> Can flags with and without suppress_required set be mixed?
Yes. The only effect of that field is that if a flag with the
suppress_required field is given, G_parser() suppresses the normal check
that any options with ->required=YES are actually given.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1230#comment:5>
