[GRASS-dev] Re: [GRASS GIS] #1230: <suppress_required/> in r.out.gdal
GRASS GIS trac at osgeo.org
Tue Dec 7 03:43:50 EST 2010
  Reporter:  rsbivand     |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  major        |   Milestone:  7.0.0
 Component:  Raster       |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment(by rsbivand):
 Replying to [comment:4 hamish]:
 > Replying to [comment:2 rsbivand]:
 > > I have to work within the XML library linked by the XML R
 > > contributed package, so if that barfs, I'm stuck.
 > If R's XML package can't deal with <foo />, then we should probably file
 a bug with them. While not in every XML file it's a somewhat common
 creature and I'd be a little surprised if you were the first person to
 find this problem, and you certainly wont be the last.
 > Hamish
 > ps- is the missing newline after the tag real or just an artifact of the
 trac editor?
 Hamish: the trac editor, in a gnome terminal there is a newline between
 <suppress_required/> and <description>, both are equally indented.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1230#comment:6>
