[GRASS-dev] [GRASS GIS] #1235: ERROR: G_getenv(): Variable
LOCATION_NAME not set
trac at osgeo.org
Wed Dec 8 16:42:39 EST 2010
#1235: ERROR: G_getenv(): Variable LOCATION_NAME not set
Reporter: apgis | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
G_getenv() doesn't get the correct path from LD_LIBRARY_PATH.
For example, I setup LD_LIBRARY_PATH = C:\GRASS-64\lib in Windows XP, but
G_getenv gets LD_LIBRARY_PATH=/grass/lib that is why it appears 'ERROR:
G_getenv(): Variable LOCATION_NAME not set'.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1235>
