[GRASS-dev] Re: [GRASS GIS] #1235: ERROR: G_getenv(): Variable LOCATION_NAME not set
GRASS GIS trac at osgeo.org
Wed Dec 8 23:45:54 EST 2010
 Reporter:  apgis        |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.1
Component:  LibGIS       |     Version:  unspecified
 Keywords:               |    Platform:  MSWindows XP
      Cpu:  Unspecified  |
Changes (by hamish):
  * platform:  Unspecified => MSWindows XP
  * component:  Default => LibGIS
Comment:
 AFAIK, LD_LIBRARY_PATH is not used on non-UNIX systems. Are you using
 Cygwin?
 Is this your own code or part of the shipping binaries?
 G_getenv() actually gets GIS variables from the $HOME/.grassrc6 file.
 LD_LIBRARY_PATH is a UNIX environment variable. FWIW, environment
 variables are read by libc's getenv(). Yes, the names are similar, but the
 functionality is quite different, sorry for the confusion. See the
 "variables" grass help page for details on both.
 Typically LOCATION_NAME not being set is because it is missing from
 $HOME/.grassrc6. Probably the easiet way to fix that is to start grass
 from the command line with the full path to the mapset, e.g.
   grass64 c:\grassdata\spearfish60\user
 from then on you should be ok.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1235#comment:1>
