[GRASS-dev] recent updates to Vlib break vectors in GRASS 7
Markus Neteler
neteler at osgeo.org
Mon Dec 27 12:28:26 EST 2010
On Mon, Dec 27, 2010 at 6:14 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
> I just updated from the svn trunk and tried to compile GRASS. I noticed that there have been very recent updates to Vlib. I also hit errors in Vlib that cascaded through all the rest of the vector modules. I wonder if this is an issue with compiling to 64 bit?
> Compiling on Mac OS X 10.6. Here are the errors in Vlib.
> cmb-MBP-3:grass70_dev cmbarton$
> cmb-MBP-3:grass70_dev cmbarton$ cd /Users/Shared/grass_dev/grass70_dev/lib/vector/Vlib
> cmb-MBP-3:Vlib cmbarton$ make
> gcc -g -O2 -arch i386 -arch x86_64 -fno-common -I/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.5.0/include -I/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.5.0/include -D_FILE_OFFSET_BITS=64 -I/Library/Frameworks/GDAL.framework/Versions/1.7/Headers -I/Library/Frameworks/GEOS.framework/Versions/3/unix/include -DPACKAGE=\""grasslibs"\" -I/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.5.0/include -I/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.5.0/include -o OBJ.i386-apple-darwin10.5.0/open_ogr.o -c open_ogr.c
> In file included from open_ogr.c:26:
> /Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.5.0/include/grass/gprojects.h:21:22: error: proj_api.h: No such file or directory
-> No such file or directory
Did you
"make distclean"
and configure again?
Markus
