[GRASS-dev] recent updates to Vlib break vectors in GRASS 7
Michael Barton
Michael.Barton at asu.edu
Mon Dec 27 12:52:56 EST 2010
I did make distclean, svn up, configure, and make
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 27, 2010, at 10:28 AM, Markus Neteler wrote:
> On Mon, Dec 27, 2010 at 6:14 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> I just updated from the svn trunk and tried to compile GRASS. I noticed that there have been very recent updates to Vlib. I also hit errors in Vlib that cascaded through all the rest of the vector modules. I wonder if this is an issue with compiling to 64 bit?
>> Compiling on Mac OS X 10.6. Here are the errors in Vlib.
>> cmb-MBP-3:grass70_dev cmbarton$
>> cmb-MBP-3:grass70_dev cmbarton$ cd /Users/Shared/grass_dev/grass70_dev/lib/vector/Vlib
>> cmb-MBP-3:Vlib cmbarton$ make
>> gcc -g -O2 -arch i386 -arch x86_64 -fno-common -I/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.5.0/include -I/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.5.0/include -D_FILE_OFFSET_BITS=64 -I/Library/Frameworks/GDAL.framework/Versions/1.7/Headers -I/Library/Frameworks/GEOS.framework/Versions/3/unix/include -DPACKAGE=\""grasslibs"\" -I/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.5.0/include -I/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.5.0/include -o OBJ.i386-apple-darwin10.5.0/open_ogr.o -c open_ogr.c
>> In file included from open_ogr.c:26:
>> /Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.5.0/include/grass/gprojects.h:21:22: error: proj_api.h: No such file or directory
> -> No such file or directory
> Did you
> "make distclean"
> and configure again?
> Markus
