[GRASS-dev] Re: [GRASS GIS] #965: Location wizard: doesn't create MYNAME
GRASS GIS trac at osgeo.org
Wed Dec 29 19:17:47 EST 2010
  Reporter:  hamish  |       Owner:  martinl
      Type:  defect  |      Status:  reopened
  Priority:  normal  |   Milestone:  6.4.1
 Component:  wxGUI   |     Version:  svn-releasebranch64
Resolution:          |    Keywords:  location wizard
  Platform:  All     |         Cpu:  All
Comment(by glynn):
 Replying to [comment:7 martinl]:
 > > Or better: can python access the #defined values in the C include
 files directly as swig could?
 > Could be accessed using ctypes. Currently wxGUI is not using ctypes
 (except of 3D view mode).
 They don't exist in the library, so you can't access them directly via
 ctypes in the same way as variables (i.e.
 ctypes.CDLL("libgrass_gis.so").GNAME_MAX won't work). However, ctypesgen
 includes preprocessor macros in the generated files, so they are present
 in the grass.lib.*.py modules.
 Even so, simply importing grass.lib.* will load the corresponding dynamic
 library, which may kill the importing process if there are any problems
 (e.g. architecture or version mismatches), so I wouldn't recommend it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/965#comment:9>
