Fwd: [GRASS-dev] Scripting in Linux
Tue Feb 2 14:29:49 EST 2010
Kim Besson wrote:
> Hi Glynn. I'm really thankful for your help.
> > What does "localedef --list-archive" say?
> Uhm... It returns an empty list...
> >Those all look okay (I suspect that dgettext() is a macro which uses
> >dcgettext). Except ... glibc 2.0 is pretty old; that might be causing
> >problems.
> >How old is your system? Which versions of libc are on it?
>  Ok I'm running in Ubuntu9.10 (quite new). My libc6 (GNU C Library: Shared
> libraries) is 2.10.1 and my libc-dev-bin is also 2.10.1 and libc-bin is
> 2.10.1-0.
> >Which version does the /lib/libc.so.6 symlink point to?
>  By doing nm �D libc.so.6 I got the following (output is attached to this
> email):
> 000c0510 W symlink
> 000c0550 T symlinkat
> So, what do you think that might be happening?
At this point, I'm all out of ideas.
