Fwd: [GRASS-dev] Scripting in Linux
Kim Besson kimbesson1981 at gmail.com
Wed Feb 3 08:13:29 EST 2010
Ok Clements. Thank you. I will try to do some debugging and get back to this
as soon as possible
Thank you again. Is this a common problem or should I put this in
Bugs/errors trac list?
Kim
2010/2/2 Glynn Clements <glynn at gclements.plus.com>
> Kim Besson wrote:
> > Hi Glynn. I'm really thankful for your help.
> > > What does "localedef --list-archive" say?
> > Uhm... It returns an empty list...
> > >Those all look okay (I suspect that dgettext() is a macro which uses
> > >dcgettext). Except ... glibc 2.0 is pretty old; that might be causing
> > >problems.
> > >How old is your system? Which versions of libc are on it?
> >  Ok I'm running in Ubuntu9.10 (quite new). My libc6 (GNU C Library:
> Shared
> > libraries) is 2.10.1 and my libc-dev-bin is also 2.10.1 and libc-bin is
> > 2.10.1-0.
> > >Which version does the /lib/libc.so.6 symlink point to?
> >  By doing nm �D libc.so.6 I got the following (output is attached to this
> > email):
> > 000c0510 W symlink
> > 000c0550 T symlinkat
> > So, what do you think that might be happening?
> At this point, I'm all out of ideas.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100203/e7436e0a/attachment.html
