Fwd: [GRASS-dev] Scripting in Linux
Wed Feb 3 12:36:27 EST 2010
Kim Besson wrote:
> Is this a common problem or should I put this in
> Bugs/errors trac list?
I wouldn't file a bug report unless you discover the cause (and it's
something within GRASS), or you can at least provide a test case which
other people can reproduce.
