Fwd: [GRASS-dev] Scripting in Linux
Kim Besson kimbesson1981 at gmail.com
Wed Feb 3 13:04:33 EST 2010
Ok I rerun configure and decided to take a look to "locale -a" and I
realized that my SP languages was not installed :(.
Sorry, now it's working
Thank you for your help
Kim
2010/2/3 Glynn Clements <glynn at gclements.plus.com>
> Kim Besson wrote:
> > Is this a common problem or should I put this in
> > Bugs/errors trac list?
> I wouldn't file a bug report unless you discover the cause (and it's
> something within GRASS), or you can at least provide a test case which
> other people can reproduce.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100203/3fada3fc/attachment.html
