[GRASS-dev] [GRASS GIS] #906: r.out.gdal (VRT) broken output
GRASS GIS trac at osgeo.org
Thu Feb 4 09:59:31 EST 2010
 Reporter:  epifanio  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  6.5.0
Component:  default   |     Version:  svn-develbranch6
 Keywords:            |    Platform:  MacOSX
      Cpu:  x86-64    |
 tring to generate a VRT file using r.out.gdal i get a broken file (not
 loadable in ossim and qgis)
 using gdal_translate i get a different results.
 using  r.out.gdal
 r.out.gdal input=geology at PERMANENT format=VRT type=Byte output=name.vrt
 Exporting to GDAL data type: Byte
 Checking GDAl data type and nodata value
 Input raster map contains cells with NULL-value (no-data). The value 255
 will be used to represent no-data values in the input map. You can specify
 a nodata value with the nodata option.
 Exporting to GDAL raster
 ERROR 1: Writing through VRTSourcedRasterBand is not
 supported.
 Unable to write GDAL raster file
 Unable to export raster map <geology at PERMANENT>
 r.out.gdal complete.
 (Thu Feb  4 00:53:22 2010) Command finished (0 sec)
 i get this output :
 <VRTDataset rasterXSize="1899" rasterYSize="1398">
   <SRS>PROJCS[&quot;UTM Zone 13, Northern
 Hemisphere&quot;,GEOGCS[&quot;clark66&quot;,DATUM[&quot;North_American_Datum_1927&quot;,SPHEROID[&quot;Clarke_1866&quot;,6378206.4,294.9786982]],PRIMEM[&quot;Greenwich&quot;,0],UNIT[&quot;degree&quot;,0.0174532925199433]],PROJECTION[&quot;Transverse_Mercator&quot;],PARAMETER[&quot;latitude_of_origin&quot;,0],PARAMETER[&quot;central_meridian&quot;,-105],PARAMETER[&quot;scale_factor&quot;,0.9996],PARAMETER[&quot;false_easting&quot;,500000],PARAMETER[&quot;false_northing&quot;,0],UNIT[&quot;meter&quot;,1]]</SRS>
   <GeoTransform>  5.9001000000000000e+05,  1.0000000000000000e+01,
 0.0000000000000000e+00,  4.9280000000000000e+06,  0.0000000000000000e+00,
 -1.0000000000000000e+01</GeoTransform>
   <VRTRasterBand dataType="Byte" band="1">
     <NoDataValue>2.55000000000000E+02</NoDataValue>
     <ColorInterp>Palette</ColorInterp>
     <ColorTable>
       <Entry c1="197" c2="129" c3="125" c4="255"/>
       <Entry c1="107" c2="250" c3="75" c4="255"/>
       <Entry c1="226" c2="83" c3="250" c4="255"/>
       <Entry c1="246" c2="222" c3="188" c4="255"/>
       <Entry c1="123" c2="225" c3="27" c4="255"/>
       <Entry c1="134" c2="190" c3="1" c4="255"/>
       <Entry c1="48" c2="86" c3="221" c4="255"/>
       <Entry c1="113" c2="70" c3="15" c4="255"/>
       <Entry c1="102" c2="134" c3="101" c4="255"/>
       <Entry c1="89" c2="135" c3="169" c4="255"/>
     </ColorTable>
   </VRTRasterBand>
 </VRTDataset>
 this output is different from the gdal output :
 gdal_translate -of VRT
 /Users/sasha/Downloads/spearfish60/PERMANENT/cellhd/geology
 /Users/sasha/Desktop/geology.vrt
 <VRTDataset rasterXSize="190" rasterYSize="140">
   <GeoTransform>  5.9000000000000000e+05,  1.0000000000000000e+02,
 -1.0000000000000000e+02</GeoTransform>
   <Metadata/>
     <Metadata>
       <MDI key="COLOR_TABLE_RULES_COUNT">0</MDI>
     </Metadata>
     <NoDataValue>0.00000000000000E+00</NoDataValue>
     <ColorTable>
     </ColorTable>
     <SimpleSource>
       <SourceFilename
 relativeToVRT="0">/Users/sasha/Downloads/spearfish60/PERMANENT/cellhd/geology</SourceFilename>
       <SourceBand>1</SourceBand>
       <SourceProperties RasterXSize="190" RasterYSize="140"
 DataType="Byte" BlockXSize="190" BlockYSize="1"/>
       <SrcRect xOff="0" yOff="0" xSize="190" ySize="140"/>
       <DstRect xOff="0" yOff="0" xSize="190" ySize="140"/>
     </SimpleSource>
   </VRTRasterBand>
 </VRTDataset>
 the grass output doesn't include :
     <SimpleSource>
     </SimpleSource>
 it is missed and tring to load the output in ossim or qgis it is not
 displayed.
 from a chat on #gdal seems the problem is related to the "create_copy()"
 usage .. but i'm not able to debug it.
 thanks!
 Massimo.
Ticket URL: <http://trac.osgeo.org/grass/ticket/906>
