[GRASS-dev] Re: [GRASS GIS] #902: nviz (tcl) fails on wingrass
GRASS GIS trac at osgeo.org
Fri Feb 5 01:08:19 EST 2010
  Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  NVIZ      |     Version:  svn-trunk
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by hamish):
 With today's daily build of the WinGrass installer (r40819) "`nviz -q`"
 now works from the msys prompt. But it still doesn't work from the wxGUI.
 When you select File -> NVIZ (Tcl/Tk) the module's GUI pops up and you can
 set elev: elevation.dem by hand.
 But then when you hit [Run] you get a popup error and an error in the
 module gui output tab. The popup error reads:
 Error in command execution nviz2.2_script
 (X) Execution failed: 'nviz2.2_script elevation=elevation.dem'
 Details:
 Error:
 and in the module GUI output tab it says:
 'nviz2.2_script' is not recognized as an internal or external command,
 operable program or batch file.
 `nviz2.2_script` is at `$GISBASE/etc/nviz2.2/scripts/nviz2.2_script`
 and `$GISBASE/bin/nviz.bat` calls it.
 The gui popup window says "nviz2.2_script" as the program name in the
 window's title bar.
 From the GIS.m tcl tk gui menu it also fails, but there just with a (X) in
 the main gui output window and other feedback. You can run "nviz -q" from
 the stealth command region at the bottom of the output window + [Run]. in
 doing that it picks up the nviz icon as well. You can also start it ok
 from the GIS.m Map Display window toolbar.
 there is nothing in the help page or Usage: text about it, but fwiw
 `g.parser -s` has been backported to 6.5 but not 6.4.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:6>
