[GRASS-dev] Re: [GRASS GIS] #902: nviz (tcl) fails on wingrass
GRASS GIS trac at osgeo.org
Fri Feb 5 01:53:53 EST 2010
  Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  NVIZ      |     Version:  svn-trunk
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by glynn):
 Replying to [comment:6 hamish]:
 > With today's daily build of the WinGrass installer (r40819) "`nviz -q`"
 now works from the msys prompt. But it still doesn't work from the wxGUI.
 > When you select File -> NVIZ (Tcl/Tk) the module's GUI pops up and you
 can set elev: elevation.dem by hand.
 > But then when you hit [Run] you get a popup error and an error in the
 module gui output tab. The popup error reads:
 > Error in command execution nviz2.2_script
 Right. The "nviz" script doesn't invoke g.parser. It invokes
 "$GISBASE/etc/nviz2.2/nviz" -f
 "$GISBASE/etc/nviz2.2/scripts/nviz2.2_script"
 and the nviz binary calls G_parser() (with argv[0] set to Tcl's $argv0,
 which is the name of the script).
 One solution is to simply force argv[0] to "nviz" unless script_mode is
 set.
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:7>
