[GRASS-dev] Re: [GRASS GIS] #902: nviz (tcl) fails on wingrass
trac at osgeo.org
Fri Feb 5 04:12:37 EST 2010
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: NVIZ | Version: svn-trunk
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by hamish):
Replying to [comment:7 glynn]:
> One solution is to simply force argv[0] to "nviz" unless
> script_mode is set.
( source:grass/trunk/visualization/nviz/src/nviz_init.c, r40784)
I tried with DEBUG=2 but it dies before getting to the `G_debug(2,
"nviz_init:arg*` lines in nviz_init.c.
It dies in the same way on trunk + linux too.
* "nviz" by itself on the command line dies with a segfault:
(all versions, all platforms)
GRASS7> gdb $GISBASE/etc/nviz2.2/nviz
(gdb) run -f $GISBASE/etc/nviz2.2/scripts/nviz2.2_script
(gdb) bt
#0 0x00007f4faac098dc in strstr () from /lib/libc.so.6
#1 0x000000000041b117 in parse_command (data=0x630b40, interp=0x10e82b0,
argc=0,
argv0=0x1187a90 "/usr/local/src/grass/svn/trunk/dist.x86_64-unknown-
linux-gnu/etc/nviz2.2/scripts/nviz2.2_script", argv=0x10fa8b0) at
nviz_init.c:165
#2 0x000000000041be83 in Ninitdata (interp=0x10e82b0, data=0x630b40) at
nviz_init.c:543
#3 0x000000000041bddf in Ninit (interp=0x10e82b0, w=0x0) at
nviz_init.c:507
#4 0x000000000041abce in NVIZ_AppInit (interp=0x10e82b0) at
nvizAppInit.c:130
#5 0x00007f4fac4d47e6 in Tk_MainEx () from /usr/lib/libtk8.4.so.0
#6 0x000000000041ac82 in main (argc=3, argv=0x7fffb7eddc28) at
nvizMain.c:61
(gdb) bt full
No symbol table info available.
argc=0,
nviz_init.c:165
elev = (struct Option *) 0x7f4face2fca0
colr = (struct Option *) 0x1187c00
vct = (struct Option *) 0x1187fc0
pnt = (struct Option *) 0x1188060
vol = (struct Option *) 0x1188100
panel_path = (struct Option *) 0x11881a0
script = (struct Option *) 0x11884c0
state = (struct Option *) 0x1188560
no_args = (struct Flag *) 0x7f4face2fc70
script_kill = (struct Flag *) 0x1187b70
demo = (struct Flag *) 0x1187ca0
module = (struct GModule *) 0x7f4face2fc40
arglist = {0x0, 0x62f4d8 "\177eS®O\177", 0x0}
autoload = 0x0
i = 0
aload = 1
argv2 = (char **) 0x11882e0
argc2 = 1
ii = 0
jj = 0
nviz_init.c:543
argv0 = 0x1187a90 "/usr/local/src/grass/svn/trunk/dist.x86_64-
unknown-linux-gnu/etc/nviz2.2/scripts/nviz2.2_script"
argv = (const char **) 0x10fa8b0
argc = 0
nviz_init.c:507
data = {Zrange = 0, XYrange = 0, NumCplanes = 0, CurCplane = 0,
Cp_on = {0, 0, 0, 0, 0, 0}, Cp_trans = {{
0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}},
Cp_rot = {{0, 0, 0}, {0, 0, 0}, {0, 0, 0},
{0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, light = {{id = 0, brt = 0, r = 0, g
= 0, b = 0, ar = 0, ag = 0, ab = 0,
x = 0, y = 0, z = 0, w = 0}, {id = 0, brt = 0, r = 0, g = 0, b = 0,
ar = 0, ag = 0, ab = 0, x = 0, y = 0,
z = 0, w = 0}, {id = 0, brt = 0, r = 0, g = 0, b = 0, ar = 0, ag =
0, ab = 0, x = 0, y = 0, z = 0, w = 0}},
BGcolor = 0}
nvizAppInit.c:130
No locals.
nvizMain.c:61
what does ~/.nvizrc do? it is just ~/.nvwishrc by another name?
to be honest nviz's startup method is (and always has been) about as
confusing to me as the custom osgeo4w grass64.bat startup method is. I
think I need to slowly draw out a large flowchart for both :)
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:8>
