[GRASS-dev] GRASS_ADDON_PATH in GRASS6.4 UbuntuOS
Kim Besson kimbesson1981 at gmail.com
Fri Feb 5 07:18:17 EST 2010
Hello Hamish
My question, and I think Franz's, has nothing to do with msys. We are
questioning this in a linux OS system.
Like I said, if I use Cmd> prompt in the GUI, I get an error stating that I
should insert required data and prints all commands.
But your suggestion seems to have some effect
beucase CMD> i.ndvi --ui
It opened the module/GUI but it freezes when I run (and it never freezers if
it's in Scripts/) and it seems to be putting g.messasges in the command
output.
But GRASS has freezed. And when I treied to stop it printed the following
error:
(anrr:2019): Gtk-CRITICAL **: gtk_widget_event: assertion
`WIDGET_REALIZED_FOR_EVENT (widget, event)' failed
  File "/usr/local/grass-6.4.0svn/etc/wxpython/gui_modules/g
output.py", line 486, in OnCmdAbort
    self.cmdThread.abort()
output.py", line 108, in abort
    self.requestCmd.abort()
AttributeError: 'CmdThread' object has no attribute
'requestCmd'
Is it suppose to run scripts, from ADDON_PATH, only in the GUI command-line?
if running from the msys prompt, try to run it as "g.module --ui", or
> just the module name from the Cmd> prompt in the GUI.
> I find it strange that about 5 of us are all noticing this in the last
> day or two and yet apparently it's been like that forever. Maybe the way
> it fails has changed and now we are just getting further than we ever
> did before?
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100205/07d6e3af/attachment.html
