[GRASS-dev] grass7 build on osx snow leopard
Massimo Di Stefano
massimodisasha at gmail.com
Fri Feb 5 09:17:41 EST 2010
Il giorno 05/feb/2010, alle ore 13.15, Markus Neteler ha scritto:
> On Thu, Feb 4, 2010 at 9:59 PM, Massimo Di Stefano
> <massimodisasha at gmail.com> wrote:
>> " svn up "
>> Changeset [40820]+
>> Changeset [40821]
>> fix the errors.
>> now v.lidar.correction builds without errors.
>>> Massimo Di Stefano wrote:
>>>> Errors in:
>>>> /Users/Shared/source/grass_trunk/visualization/nviz
>>>> /Users/Shared/source/grass_trunk/visualization/xganim
>>>> /Users/Shared/source/grass_trunk/visualization/wximgview
> please also post the errors in these directories.
> Markus
yes True,
i'm on osx snow leopard building with multi-arch flags,
this what i'm doing :
export CXXFLAGS="-arch x86_64 -arch i386 -Os -g"
export LDFLAGS="-arch x86_64 -arch i386 -Os -g"
export CFLAGS="-arch x86_64 -arch i386 -Os -g"
export NAD2BIN=/Library/Frameworks/PROJ.framework/Programs/nad2bin
./configure --with-freetype --with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2 /Library/Frameworks/FreeType.framework/unix/include" --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/Frameworks/GDAL.framework/unix/bin/gdal-config --with-geos=/Library/Frameworks/GEOS.framework/Programs/geos-config --with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --without-mysql --with-odbc --with-sqlite --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include --with-fftw-includes=/Users/Shared/source/epylib/local/include --with-fftw-libs=/Users/Shared/source/epylib/local/lib --with-cxx --with-x --without-motif --without-glw --with-opengl=aqua --without-readline --with-python --with-wxwidgets=/usr/bin/wx-config --prefix=/Applications --enable-macosx-app --with-cairo --with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo /Library/Frameworks/cairo.framework/unix/include" --with-cairo-libs=/Library/Frameworks/cairo.framework/Versions/1/unix/lib --with-cairo-ldflags=-lcairo --with-pthread --with-postgres --with-postgres-includes=/usr/local/pgsql/include --with-postgres-libs=/usr/local/pgsql/lib --enable-largefile --with-macosx-archs="i386 x86_64"
make
Started compilation: Ven 5 Feb 2010 14:42:10 CET
Errors in:
logs :
nviz : http://www.geofemengineering.it/data/nviz.txt
xganim : http://www.geofemengineering.it/data/xganim.txt
wximgview : http://www.geofemengineering.it/data/wximgview.txt
