[GRASS-dev] grass7 build on osx snow leopard
William Kyngesburye
woklist at kyngchaos.com
Fri Feb 5 09:35:58 EST 2010
Ah, when you use the arch option in configure, do NOT set archs in C[XX]FLAGS/LDFLAGS as this will override the arch option and mess up all wxpython-based modules.
On Feb 5, 2010, at 8:17 AM, Massimo Di Stefano wrote:
>>>>> /Users/Shared/source/grass_trunk/visualization/nviz
>>>>> /Users/Shared/source/grass_trunk/visualization/xganim
>>>>> /Users/Shared/source/grass_trunk/visualization/wximgview
>> please also post the errors in these directories.
>> Markus
> yes True,
> i'm on osx snow leopard building with multi-arch flags,
> this what i'm doing :
> export CXXFLAGS="-arch x86_64 -arch i386 -Os -g"
> export LDFLAGS="-arch x86_64 -arch i386 -Os -g"
> export CFLAGS="-arch x86_64 -arch i386 -Os -g"
> export NAD2BIN=/Library/Frameworks/PROJ.framework/Programs/nad2bin
> ./configure --with-freetype --with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2 /Library/Frameworks/FreeType.framework/unix/include" --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/Frameworks/GDAL.framework/unix/bin/gdal-config --with-geos=/Library/Frameworks/GEOS.framework/Programs/geos-config --with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --without-mysql --with-odbc --with-sqlite --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include --with-fftw-includes=/Users/Shared/source/epylib/local/include --with-fftw-libs=/Users/Shared/source/epylib/local/lib --with-cxx --with-x --without-motif --without-glw --with-opengl=aqua --without-readline --with-python --with-wxwidgets=/usr/bin/wx-config --prefix=/Applications --enable-macosx-app --with-cairo --with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo /Library/Frameworks/cairo.framework/unix/include" --with-cairo-libs=/Library/Frameworks/cairo.framework/Versions/1/unix/lib --with-cairo-ldflags=-lcairo --with-pthread --with-postgres --with-postgres-includes=/usr/local/pgsql/include --with-postgres-libs=/usr/local/pgsql/lib --enable-largefile --with-macosx-archs="i386 x86_64"
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
