[GRASS-dev] scripts don't launch GUI from the msys command line in winGRASS
Michael Barton Michael.Barton at asu.edu
Fri Feb 5 12:58:46 EST 2010
On Feb 4, 2010, at 11:55 PM, Hamish wrote:
> Michael wrote:
>> #### first issue
>> So far, I've only seen this in Vista and am wondering if
>> anyone else has seen it. Using the nightly build from 2
>> February.
>> From the command line, type the name of a script, like
>> r.blend, without arguments
>> Instead of the GUI popping up, there is an error
>> complaining about the lack of arguments.
> it's funny that we all noticed this at the same time, but actually it
> is all modules and it's been like that for a long time (if not always).
> I had tried a WinGrass installer from December (well before the latest
> rounds of argv[0] and G_spawn() changes) and it was the same. --ui is
> needed from the msys prompt.
> I tried from the DOS prompt as well (even setting GRASS_GUI=wxpython),
> but that just returns you to the C:\> prompt. You can start g.gui from
> there ok though.   shrug.
Odd. I guess it's that we don't use Windows regularly enough to spot this kind of thing. It underscores the need for more
Windows testers.
>> ### second issue
>> Also,  copy a script and rename the copy (e.g., copy
>> r.blend to r.blend2), leaving it in the scripts folder, then
>> copy the script's *.bat file (in bin), rename the copy
>> (e.g., , e.g., r.blend.bat to r.bend2.bat), and edit the
>> *.bat file so that it points to the proper renamed script
>> copy (e.g., now points to r.blend2). Type the script's name
>> on the msys command line and press return.
>> There is an error that the script cannot be found.
>> Any thoughts?
> .. perhaps restart GRASS? ?
I'll suggest it.
>> I'm trying to help some students learn scripting. It is
>> frustrating that even correctly written scripts don't work.
> understood.
If we can get the Python thing worked out I keep hoping that this will all improve a lot.
MIchael
