[GRASS-dev] Re: [GRASS GIS] #909: FTBFS: r.mapcalc in trunk
GRASS GIS trac at osgeo.org
Fri Feb 5 14:19:33 EST 2010
  Reporter:  hamish     |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect     |      Status:  new
  Priority:  normal     |   Milestone:  7.0.0
 Component:  Compiling  |     Version:  svn-trunk
Resolution:             |    Keywords:  r.mapcalc
  Platform:  Linux      |         Cpu:  x86-64
Comment (by glynn):
 Replying to [ticket:909 hamish]:
 > latest trunk:
 > "make -j8" on debian/stable, 64bit quad-core
 gcc ... OBJ.x86_64-unknown-linux-gnu/mapcalc.yy.o ...
 /usr/local/src/grass/svn/trunk/raster/r.mapcalc/mapcalc.tab.c:1442:
 undefined reference to `yylex'
 /usr/local/src/grass/svn/trunk/raster/r.mapcalc/mapcalc.y:270: undefined
 reference to `initialize_scanner_string'
 These should be in mapcalc.yy.o, compiled from mapcalc.yy.c, generated by
 lex from mapcalc.l.
 mapcalc.yy.o is in the list of object files being linked, so make knows
 that it needs to build it and believes that it has done so, and gcc isn't
 complaining about its absence. Can you provide the make output
 corresponding to the generation and compilation of mapcalc.yy.c?
Ticket URL: <https://trac.osgeo.org/grass/ticket/909#comment:2>
