[GRASS-dev] Re: [GRASS GIS] #909: FTBFS: r.mapcalc in trunk
trac at osgeo.org
Fri Feb 5 14:49:35 EST 2010
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Resolution: | Keywords: r.mapcalc
Platform: Linux | Cpu: x86-64
Comment (by glynn):
Replying to [comment:1 hamish]:
> also, I noticed this whiz by:
mapcalc.l:216: warning, -s option given but default rule can be matched
Harmless. It indicates that not all possible inputs are valid, i.e. it's
possible for the expression to have syntax errors. Using the -s flag
causes syntax errors to generate an error rather than silently writing
unmatched text to stdout.
Ticket URL: <https://trac.osgeo.org/grass/ticket/909#comment:3>
