[GRASS-dev] Re: [GRASS GIS] #909: FTBFS: r.mapcalc in trunk
trac at osgeo.org
Sun Feb 7 21:42:53 EST 2010
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Resolution: | Keywords: r.mapcalc
Platform: Linux | Cpu: x86-64
Comment (by hamish):
Replying to [comment:2 glynn]:
> These should be in mapcalc.yy.o, compiled from mapcalc.yy.c,
> generated by lex from mapcalc.l.
> mapcalc.yy.o is in the list of object files being linked, so
> make knows that it needs to build it and believes that it has done
> so, and gcc isn't complaining about its absence. Can you provide
> the make output corresponding to the generation and compilation of
> mapcalc.yy.c?
sure. due to the -j8 the output is a bit jumbled up so I'll send you the
entire build log off-list. I just tried again today and it built ok, but I
guess who wins the race is just a whim of timing.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/909#comment:4>
