[GRASS-dev] [GRASS GIS] #911: v.parallel: user interface change in 6.x line
GRASS GIS trac at osgeo.org
Sat Feb 6 09:51:24 EST 2010
 Reporter:  msieczka  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  6.4.0
Component:  Vector    |     Version:  svn-develbranch6
 Keywords:            |    Platform:  All
      Cpu:  All       |
 There is a user interface change to v.parallel in GRASS 6.x. The option
 `distance' does not accept negative offsets anymore, and introduces a new
 `side' option to distinguish left/right, instead.
 Before v.parallel2, v.parallel used to accept negative numbers for dist.
 Now it fails:
 $ v.parallel in=lines out=lines_par dist=-1
 ERROR: value <-1> out of range for parameter <distance>
        Legal range: 0-100000000
 I guess such a change to user interface within a stable release line is
 not allowed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/911>
