[GRASS-dev] Re: [GRASS GIS] #911: v.parallel: user interface change in 6.x line
GRASS GIS trac at osgeo.org
Tue Feb 16 07:20:20 EST 2010
  Reporter:  msieczka  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  blocker   |   Milestone:  6.4.0
 Component:  Vector    |     Version:  svn-develbranch6
Resolution:            |    Keywords:  v.parallel
  Platform:  All       |         Cpu:  All
Changes (by hamish):
  * keywords:  => v.parallel
Comment:
 fixed in devbr6 with r41042. please test.
 module is still rather buggy, & it gets differently worse after
 v.build.polylines. (test map: railroads at spearfish)
 - see v.buffer bug report, it's the same lib fn causing problems AFAIK.
 I didn't figure out how to get angle= to work. maybe I need minordistance
 for that? (docs needed)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/911#comment:1>
