[GRASS-dev] grass + matplotlib on mac osx snow leopard
Massimo Di Stefano
massimodisasha at gmail.com
Mon Feb 8 06:11:51 EST 2010
Hi All,
I'm working on a script to generate graph from grass using matplotlib
the script works fine on linux , but on osx it works only by command line
the script is :
https://svn.osgeo.org/grass/grass-addons/raster/r.ipso
the error tring to run it on osx is :
GRASS 7.0.svn (spearfish60):~ > r.ipso.py
File "/Library/Application Support/GRASS/7.0/Modules/bin/r.ipso.py", line 27, in <module>
import matplotlib.pyplot as plt
File "/Library/Python/2.6/site-packages/matplotlib-1.0.svn_r7892-py2.6-macosx-10.6-universal.egg/matplotlib/pyplot.py", line 7, in <module>
from matplotlib.figure import Figure, figaspect
File "/Library/Python/2.6/site-packages/matplotlib-1.0.svn_r7892-py2.6-macosx-10.6-universal.egg/matplotlib/figure.py", line 18, in <module>
from axes import Axes, SubplotBase, subplot_class_factory
File "/Library/Python/2.6/site-packages/matplotlib-1.0.svn_r7892-py2.6-macosx-10.6-universal.egg/matplotlib/axes.py", line 12, in <module>
import matplotlib.axis as maxis
File "/Library/Python/2.6/site-packages/matplotlib-1.0.svn_r7892-py2.6-macosx-10.6-universal.egg/matplotlib/axis.py", line 10, in <module>
import matplotlib.font_manager as font_manager
File "/Library/Python/2.6/site-packages/matplotlib-1.0.svn_r7892-py2.6-macosx-10.6-universal.egg/matplotlib/font_manager.py", line 52, in <module>
from matplotlib import ft2font
ImportError: dlopen(/Library/Python/2.6/site-packages/matplotlib-1.0.svn_r7892-py2.6-macosx-10.6-universal.egg/matplotlib/ft2font.so, 2): Symbol not found: _FT_Attach_File
Referenced from: /Library/Python/2.6/site-packages/matplotlib-1.0.svn_r7892-py2.6-macosx-10.6-universal.egg/matplotlib/ft2font.so
Expected in: flat namespace
in /Library/Python/2.6/site-packages/matplotlib-1.0.svn_r7892-py2.6-macosx-10.6-universal.egg/matplotlib/ft2font.so
i have the same error in grass64 and 65 too.
have you any hints about ?
maybe matplotlib is build on my osx only in 64 bit mode .. and this generate the problems, how to debug ?
if (from grass) i start python and try yo import " from matplotlib import ft2font " i have no errors.
thanks for any suggestion.
Massimo.
