[GRASS-dev] Python Scripts- mapcalc
Tue Feb 16 00:47:13 EST 2010
antonio.rocha at deimos.com.pt wrote:
> That is strange and unexpected. Do you just copy the python file to the
> Scripts folder or do you use Makefiles?
I just saved the attachment, added execute pemission, and ran it.
> What can I do debug some sort of problem because it really freezes my
> GRASS and it doesn't do anything?
As Hamish suggests, are you sure that you aren't trying to run it with
an excessively large region?
Is r.mapcalc showing up in the output from "ps"?
Do you see files being written to the temporary directory:
	<database>/<location>/<mapset>/.tmp/<hostname>/
