[GRASS-dev] Re: [GRASS GIS] #905: WinGrass: include patched
msys.bat in the WinGrass-Installer
trac at osgeo.org
Mon Feb 8 08:07:24 EST 2010
#905: WinGrass: include patched msys.bat in the WinGrass-Installer
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: closed
Priority: normal | Milestone: 6.4.0
Component: Packaging | Version: svn-develbranch6
Resolution: fixed | Keywords: wingrass, msys
Platform: MSWindows Vista | Cpu: Unspecified
Comment (by hamish):
Re: rxvt isatty(0) on Windows
Keith Marshall wrote:
> This feature has been known for a long time. Considerable futile effort
> has been expended on trying to fix it; we will not pursue it further.
> Since the formal release of MSYS-1.0.11, IIRC, we have recommended
against
> using rxvt as a terminal emulator for MSYS; you should use a standard
> Windows console, or Console2, (a separate SF hosted project), instead.
The
> maintainer of rxvt, (for both MSYS and Cygwin), is on record recently on
> the MinGW-dvlpr list, stating that "rxvt *must* die" on both platforms.
Ticket URL: <https://trac.osgeo.org/grass/ticket/905#comment:7>
