re [GRASS-dev] g.proj -p - units is : meters or metres ?
Tue Feb 9 23:26:14 EST 2010
Hamish wrote:
> > Changing the default won't affect existing users.
> > Personally, I'd be
> > inclined to change existing users' settings as well; they
> > can always
> > change them back if they actually want it enabled. I
> > suspect that most
> > people have it enabled simply because they don't know about
> > it.
> I would be annoyed if someone changed this for me without asking.
> This setting saves me time.
While for other people, it results in them never seeing a reply to
their question.
If it was turned off, you'd know about it the first time that you got
a duplicate reply. If it's left on, people won't notice that they're
losing emails unless they happen to look at the archives or if someone
replies to the reply.
