[GRASS-dev] v.in.ogr - Buffer overflow error.v.in.ogr buffer overflow detected
Casey Vandenberg casey.vandenberg at sjgeophysics.com
Mon Feb 8 12:21:08 EST 2010
I know this problem has crept up before for some people, but has anyone
encountered this, or resolved this problem using a 9.10 build of Ubuntu?
Any advice would be appreciated,
Casey
GRASS 6.4.0svn (NewShoshoni):~ > *** buffer overflow detected ***:
v.in.ogr terminated
======= Backtrace:
/lib/libc.so.6(__fortify_fail+0x37)[0x7fe5714725f7]
/lib/libc.so.6[0x7fe5714715a0]
/lib/libc.so.6[0x7fe571470c9b]
/lib/libc.so.6(__snprintf_chk+0x7a)[0x7fe571470b6a]
/usr/lib/libgdal1.5.0.so.1(_ZN10OGRFeature16GetFieldAsStringEi+0x302)[0x7fe5721924d2]
v.in.ogr(main+0x279b)[0x407237]
/lib/libc.so.6(__libc_start_main+0xfd)[0x7fe571399abd]
v.in.ogr[0x4039d9]
======= Memory map:
00400000-0040a000 r-xp 00000000 08:01 17900
/usr/local/grass-6.4.0svn/bin/v.in.ogr
00609000-0060a000 r--p 00009000 08:01 17900
0060a000-0060b000 rw-p 0000a000 08:01 17900
01346000-01367000 rw-p 00000000 00:00 0
[heap]
7fe5680ce000-7fe5680da000 r-xp 00000000 08:01 601
/lib/libnss_files-2.10.1.so
7fe5680da000-7fe5682d9000 ---p 0000c000 08:01 601
7fe5682d9000-7fe5682da000 r--p 0000b000 08:01 601
7fe5682da000-7fe5682db000 rw-p 0000c000 08:01 601
7fe5682db000-7fe5682e5000 r-xp 00000000 08:01 611
/lib/libnss_nis-2.10.1.so
7fe5682e5000-7fe5684e4000 ---p 0000a000 08:01 611
7fe5684e4000-7fe5684e5000 r--p 00009000 08:01 611
7fe5684e5000-7fe5684e6000 rw-p 0000a000 08:01 611
7fe5684e6000-7fe5684ed000 r-xp 00000000 08:01 597
/lib/libnss_compat-2.10.1.so
7fe5684ed000-7fe5686ed000 ---p 00007000 08:01 597
7fe5686ed000-7fe5686ee000 r--p 00007000 08:01 597
7fe5686ee000-7fe5686ef000 rw-p 00008000 08:01 597
7fe5686ef000-7fe5687e3000 r-xp 00000000 08:01 16382
/usr/lib/libfftw3.so.3.2.3
7fe5687e3000-7fe5689e2000 ---p 000f4000 08:01 16382
7fe5689e2000-7fe5689e9000 r--p 000f3000 08:01 16382
7fe5689e9000-7fe5689ea000 rw-p 000fa000 08:01 16382
7fe5689ea000-7fe568a28000 r-xp 00000000 08:01 592
/lib/libncurses.so.5.7
7fe568a28000-7fe568c28000 ---p 0003e000 08:01 592
7fe568c28000-7fe568c2c000 r--p 0003e000 08:01 592
7fe568c2c000-7fe568c2d000 rw-p 00042000 08:01 592
7fe568c2d000-7fe568c33000 r-xp 00000000 08:01 789964
/usr/lib/grass64/lib/libgrass_gmath.6.4.0RC5.so
7fe568c33000-7fe568e32000 ---p 00006000 08:01 789964
7fe568e32000-7fe568e33000 r--p 00005000 08:01 789964
7fe568e33000-7fe568e34000 rw-p 00006000 08:01 789964
7fe568e34000-7fe568e38000 r-xp 00000000 08:01 789978
/usr/lib/grass64/lib/libgrass_vask.6.4.0RC5.so
7fe568e38000-7fe569037000 ---p 00004000 08:01 789978
7fe569037000-7fe569038000 r--p 00003000 08:01 789978
7fe569038000-7fe569039000 rw-p 00004000 08:01 789978
7fe569039000-7fe56903a000 rw-p 00000000 00:00
0
7fe56903a000-7fe569043000 r-xp 00000000 08:01 789982
/usr/lib/grass64/lib/libgrass_I.6.4.0RC5.so
7fe569043000-7fe569242000 ---p 00009000 08:01 789982
7fe569242000-7fe569243000 r--p 00008000 08:01 789982
7fe569243000-7fe569244000 rw-p 00009000 08:01 789982
7fe569244000-7fe569250000 r-xp 00000000 08:01 16454
/usr/lib/gdal15plugins/ogr_GRASS.so
7fe569250000-7fe56944f000 ---p 0000c000 08:01 16454
7fe56944f000-7fe569450000 r--p 0000b000 08:01 16454
7fe569450000-7fe569451000 rw-p 0000c000 08:01 16454
7fe569451000-7fe569454000 r-xp 00000000 08:01 578
/lib/libgpg-error.so.0.4.0
7fe569454000-7fe569653000 ---p 00003000 08:01 578
7fe569653000-7fe569654000 r--p 00002000 08:01 578
7fe569654000-7fe569655000 rw-p 00003000 08:01 578
7fe569655000-7fe569665000 r-xp 00000000 08:01 3333
/usr/lib/libtasn1.so.3.1.5
7fe569665000-7fe569864000 ---p 00010000 08:01 3333
7fe569864000-7fe569865000 r--p 0000f000 08:01 3333
7fe569865000-7fe569866000 rw-p 00010000 08:01 3333
7fe569866000-7fe56987f000 r-xp 00000000 08:01 3277
/usr/lib/libsasl2.so.2.0.23
7fe56987f000-7fe569a7e000 ---p 00019000 08:01 3277
7fe569a7e000-7fe569a7f000 r--p 00018000 08:01 3277
7fe569a7f000-7fe569a80000 rw-p 00019000 08:01 3277
7fe569a80000-7fe569a96000 r-xp 00000000 08:01 638
/lib/libresolv-2.10.1.so
7fe569a96000-7fe569c95000 ---p 00016000 08:01 638
7fe569c95000-7fe569c96000 r--p 00015000 08:01 638
7fe569c96000-7fe569c97000 rw-p 00016000 08:01 638
