[GRASS-dev] v.in.ogr - Buffer overflow error.v.in.ogr buffer overflow detected
Markus Metz markus.metz.giswork at googlemail.com
Mon Feb 8 13:10:31 EST 2010
Casey Vandenberg wrote:
> Hi,
> I know this problem has crept up before for some people, but has
> anyone encountered this, or resolved this problem using a 9.10 build
> of Ubuntu?
> Any advice would be appreciated,
It seems there are two versions of grass installed, you are using
6.4.0svn, and gdal/ogr links against 6.4.0RC5. That could be a problem, see
> GRASS 6.4.0svn (NewShoshoni):~ >
and
> /usr/local/grass-6.4.0svn/bin/v.in.ogr
but
> /usr/lib/grass64/lib/libgrass_I.6.4.0RC5.so
and
> /usr/lib/gdal15plugins/ogr_GRASS.so
Maybe it helps to uninstall 6.4.0RC5, also removing the GDAL-GRASS plugin.
Just a guess,
Markus M
