#916: GRASS 7: make install fails with --prefix
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: Unspecified |
When using
./configure --prefix=/some/path
compiling and then running
make install
a series of bugs appear which indicate that the --prefix path
was not properly propagated. The problem might be that the
Makefile no longer has an "install" target (guessing).
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/916>
