[GRASS-dev] Grass7 - Trunk Install from svn question
Markus Neteler
neteler at osgeo.org
Mon Feb 8 18:57:53 EST 2010
On Tue, Feb 9, 2010 at 12:48 AM, Casey Vandenberg
<casey.vandenberg at sjgeophysics.com> wrote:
> I was trying to install grass7.0 through svn so I could do some testing and
> see some of the future development. I had no errors after typing in make,
> but when I make install I get the following:
> root at silver:/usr/local/src/grass_trunk# make install
> echo /usr/local/src/grass_trunk/bin.x86_64-unknown-linux-gnu/grass70
> /usr/local/src/grass_trunk/bin.x86_64-unknown-linux-gnu/grass70 make[1]:
> Entering directory `/usr/local/src/grass_trunk' test -d
> /usr/local/grass-7.0.svn || mkdir -p -m 755 /usr/local/grass-7.0.svn
> test -d || mkdir -p -m 755
> sed -e "s#^GISBASE.*#GISBASE=/usr/local/grass-7.0.svn#"
> /usr/local/src/grass_trunk/bin.x86_64-unknown-linux-gnu/grass70.sh >
> /grass70.sh
> sed -e 's#^gisbase = ".*"#gisbase = "/usr/local/grass-7.0.svn"#'
> /usr/local/src/grass_trunk/bin.x86_64-unknown-linux-gnu/grass70 > /grass70
> chmod a+x /grass70
> tar cBCf /usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu - . | tar
> xBCf /usr/local/grass-7.0.svn - 2>/dev/null sed
> 's#'/usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu'#'/usr/local/grass-7.0.svn'#g'
> /usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/fontcap >
> /usr/local/grass-7.0.svn/etc/fontcap
> /usr/bin/install -c config.status /usr/local/grass-7.0.svn/config.status
> chmod -R a+rX /usr/local/grass-7.0.svn 2>/dev/null
> tar cBf - gem/skeleton | tar xBCf /usr/local/grass-7.0.svn/etc - 2>/dev/null
> /usr/bin/install -c gem/gem70 2>/dev/null
> make[1]: [real-install] Error 1 (ignored)
> make[1]: Leaving directory `/usr/local/src/grass_trunk'
> I can not seem to get the install made, any pointers on this one.
"Amusingly", I have opened a similar ticket in the same moment:
http://trac.osgeo.org/grass/ticket/916
Hint for now: no need to install GRASS, you can use it right away
from the compile directory (bin.ARCH/grass70).
Markus
