[GRASS-dev] Some proposition on r.neighbour (new code)
Jarosław Jasiewicz
jarekj at amu.edu.pl
Tue Feb 9 06:52:11 EST 2010
Hi All
I have two propositions on r.neighbour:
1) add existing method "range" to existing methods of r.neighbors
it is only only one line:
{c_max, NULL, NO_CATS, 1, 0, "maximum", "highest value"},
+ {c_range, NULL, NO_CATS, 1, 0, "range", "maximum - minimum"},
{c_stddev, w_stddev, NO_CATS, 0, 1, "stddev", "standard deviation"},
reason:
parameter "range" can be calculated as max-min, but it require three
calculation: r.neigbour twice, and r.mapcalc one. For large maps and
large window it takes lot of time. That parameter is broadly used in
geomorphology as "relief energy" equivalent and as far as I know is
frequently calculated (of course not only in GRASS GIS)
2) add new method "percentile" and add it to existing method of r.neighbours
I attached code as percentile2.c. For testing purpose I added it to
directory r.neighbors, and add one line into methods:
{c_perc, NULL, NO_CATS, 0, 0, "percentile", "percentile of center
value"},
reason:
method "percentile" returns the percentile of the central cell. If it is
max cell in the neighbor it returns 1 in smallest it returns 1/cell_count.
That parameter can be use in geomorphology to determine valleys (usually
values lower than first quartile: 0.25) and ridges (usually values
grater than 3th quartile 0.75). I send it to GRASS DEV Because I'd like
to share this code with other grass users, and the easiest way is to add
this parameter to GRASS is expand r.neighbors (creating ADD_ON
r.neigbors fork or completely new module only for one parameter is
nonsense).
regards
Jarek Jasiewicz
Type: text/x-csrc
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20100209/4bb850db/percentile2.bin
