[GRASS-dev] Some proposition on r.neighbour (new code)
Tue Feb 9 18:36:59 EST 2010
Jarosław Jasiewicz wrote:
> I have two propositions on r.neighbour:
> 1) add existing method "range" to existing methods of r.neighbors
> 2) add new method "percentile" and add it to existing method of r.neighbours
Both seem reasonable, although I'm not keen on the name of the second.
1. It's likely to be confused as being similar to quart1, quart3,
perc90 and quantile (quantile would have been named percentile if it
used values in the range 0-100 rather than 0-1).
2. The name shouldn't mention percentile unless the range is 0-100.
