[GRASS-dev] Re: [GRASS GIS] #902: nviz (tcl) fails on wingrass
trac at osgeo.org
Tue Feb 9 18:55:07 EST 2010
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: NVIZ | Version: svn-trunk
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by glynn):
Replying to [comment:19 hamish]:
> With the latest nightly WinGrass 6.4.0svn build (r40876), I get this
error message if 'nviz --ui' is called from the msys command line,
elev=elevation.dem at PERM, and the '-v' verbose flag is ticked (one -, not
two).
> the popup window error is:
unknown or ambiguous visual name "elevation=elevation at PERMANENT":
Tk uses -v itself (it's an abbreviation for -visual). This specific issue
can be worked around by using "--" in the nviz script, i.e.
-exec "$GISBASE/etc/nviz2.2/nviz" -f
"$GISBASE/etc/nviz2.2/scripts/nviz2.2_script" ${1+"$@"}
+exec "$GISBASE/etc/nviz2.2/nviz" -f
"$GISBASE/etc/nviz2.2/scripts/nviz2.2_script" -- ${1+"$@"}
But I'm more inclined to suggest back-porting r40879. I think that's bound
to be the most robust solution.
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:21>
