[GRASS-dev] Re: [GRASS GIS] #902: nviz (tcl) fails on wingrass
GRASS GIS trac at osgeo.org
Wed Feb 10 16:37:21 EST 2010
  Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  NVIZ      |     Version:  svn-trunk
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by hamish):
 Following the conservative path of least change I've committed the "--"
 solution to the 6.4 branch. For wider testing I'd like to backported
 r40879 to the 6.5 branch, but I got stuck in the merge conflicts. I had to
 comment out Vars.make as it doesn't exist and getCat.c was failing because
 it couldn't find V2_area_att() and V2_line_att(). I'm not sure where those
 are supposed to come from.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:22>
