[GRASS-dev] Re: [GRASS GIS] #902: nviz (tcl) fails on wingrass
trac at osgeo.org
Wed Feb 10 20:45:49 EST 2010
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: NVIZ | Version: svn-trunk
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by glynn):
Replying to [comment:22 hamish]:
> Following the conservative path of least change I've committed the "--"
solution to the 6.4 branch. For wider testing I'd like to backported
r40879 to the 6.5 branch, but I got stuck in the merge conflicts. I had to
comment out Vars.make as it doesn't exist and getCat.c was failing because
it couldn't find V2_area_att() and V2_line_att(). I'm not sure where those
are supposed to come from.
r40879 doesn't touch those files.
I've found using "svn merge" between branches is more trouble than it's
worth. It's easier to use e.g.:
cd /path/to/7.0.svn
svn diff -c 40879 > nviz.patch
cd ../6.5
patch -p0 < ../7.0.svn/nviz.patch
This still produces some failures, but it doesn't try to merge unrelated
changes.
I'm test-compiling a manual back-port at the moment; I'll attach the patch
one I've verified that it compiles.
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:23>
